Toyota DUET, Daihatsu SIRION / STORIA 1998-2004 - manual repair, maintenance and operation of the vehicle.
The guide provides step-by-step procedures for operation, maintenance and repair front-wheel drive and all-wheel drive Toyota DUET Daihatsu SIRION / STORIA 1998-2004 years of release equipped gasoline engines EJ-DE (1,0 l), EJ-VE (1.0 liters DVVT), K3-VE (1.3 liter) and K3-VE 2(1.3 liter).
The publication contains detailed information on the verification of control system components gasoline engines, systems of variable valve timing (DVVT), lubrication, cooling, starting and charging. Provides instructions for using the system self-diagnostic engine, automatic transmission, ABS, EBD, VSC, TCS, SRS and recommendations for adjustment and repair of engines, mechanical and automatic transmissions, transfer case, brake components (including ABS), electronic brake distribution (EBD), electronic stability program (VSC), traction control system (TCS), restraint system (SRS), steering and suspension.
Presents wiring diagrams and the description of checks of electrical components. Lists the possible malfunctions and methods of their elimination, mating dimensions of the main parts and limits of their allowable wear, recommended lubricants and working fluids. The book is intended for car owners, the staff of service stations and repair shops.
