Daewoo Nexia 1995, restyled 2008 - manual repair, maintenance and operation of the vehicle.
Repair manual, operation and maintenance of car Daewoo Nexia N-100 / Daewoo Nexia N-150 with the 2008 release, equipped with petrol engine G15MF (1.5 l SOHC), A15SMS (1.5 l SOHC), A15MF (1.5 l DOHC) and F16MF (1.6 l DOHC).
We offer you a guide to repair and maintenance of car Daewoo Nexia release since 1995 (N100) and after restyling 9, 2008 (N1501 In the publication discussed in detail the car device, recommendations lo the maintenance and repair. A special section is dedicated to faults in the path and methods to diagnose and resolve them.
All the subsections in which are described the maintenance and repair of units and systems, contain lists of possible malfunctions and recommendations for their elimination, as well as guidance on disassembly, Assembly, adjustment and repair of components and vehicle systems using a standard set of tools in a garage.
Adjustment operations, disassembly, Assembly and repair of the car equipped with icons describing the complexity of work, number of workers, location of work and time required for its execution.
Instructions for dismantling, Assembly, adjustment and repair of components and systems
a car using a stock of spare parts and aggregates of the given process in detail and illustrated with color photographs and drawings, through which even a novice car owner can easily understand in repair operations.
Structurally, all repairs are divided into systems and units where they are (starting from the engine to the body). As required operations is provided with the alerts and tips based on the practices of experienced motorists.
The structure of the book is made so. what photos or drawings without a serial number are graphical complement to the subsequent paragraphs. When the described work which include intermediate operations, the latter is indicated in the form of links to the section and page where they described in detail.
The annexes contain the necessary for operation, maintenance and repair data on the tightening torques for the threaded connection of combustive-lubricating materials and operating fluids used lamps and spark plugs, as well as the body sizes.
At the end of the book contains color wiring diagrams.
The book is intended for car enthusiasts and professionals one HUNDRED
Publisher: Third Rome
